Stat Routing Problem
Oct 29th, 2008
I have a weird routing Problem. Our network is a class (A) network with multiple remotes attached to our central site. All remote sites have default routes pointing to local router. Local router has a default route to our hosted managed firewall for Internet. Everything has worked fine until 2 days ago when an additional router had to be added. A static route was added to accomodate this of
ip route 64.57.148.118 255.255.255.255 100.100.100.220 Now all access to addresses of 64.xxx.xxx.xxx gets routed to the new router not our firewall. It appears as if it is treating everything as a class (A) network. Is there a way around this.
Router Configuration
xxxxxx#
Current configuration : 1184 bytes
version 12.2
service timestamps debug uptime
service timestamps log uptime
service udp-small-servers
service tcp-small-servers
hostname xxxxx
logging queue-limit 100
enable secret xxx
enable password xxxxx
ip subnet-zero
no voice hpi capture buffer
no voice hpi capture destination
mta receive maximum-recipients 0
interface Multilink1
ip address 10.2.1.1 255.255.0.0
ppp multilink
multilink-group 1
interface FastEthernet0/0
ip address 100.100.120.1 255.0.0.0
speed auto
duplex auto
interface Serial0/0
no ip address
encapsulation ppp
compress stac
ppp multilink
multilink-group 1
interface Serial0/1
no ip address
encapsulation ppp
compress stac
ppp multilink
multilink-group 1
interface Serial0/2
ip address 10.3.1.1 255.255.0.0
encapsulation ppp
interface Serial0/3
no ip address
shutdown
router eigrp 1
redistribute connected
network 10.0.0.0
network 100.0.0.0
auto-summary
ip http server
no ip classless
ip route 0.0.0.0 0.0.0.0 100.100.100.200
ip route 64.x.x.118 255.255.255.255 100.100.100.220
dialer-list 1 protocol ip permit
call rsvp-sync
mgcp profile default
dial-peer cor custom
line con 0
line aux 0
transport input all
line vty 0 4
password xxxxx
login
end
Overall Rating: 5 (1 ratings)
Harold Ritter Wed, 10/29/2008 - 17:20
Roy,
This appears to be an issue related to the "no ip classless" command. The traffic to 64.0.0.0/8 is probably not forwarded to the new router but rather dropped on the local router because of the stateful behavior.
Simply configure "ip classless" to fix the issue.
