LMS 3.1 config question
Oct 29th, 2008
I have installed LMS 3.1 and added the devices on the LMS and the configuration from all the devices are archived. I want to apend some configuration to the spefic device. If anybody can help me on that.
Overall Rating: 4 (1 ratings)
Joe Clarke Wed, 10/29/2008 - 21:39
If you mean you want to modify your devices' configurations using RME, this can be done using Netconfig or Config Editor. Netconfig (RME > Config Mgmt > Netconfig) is used to make small config changes to a large number of devices. Config Editor (RME > Config Mgmt > Config Editor) is used to edit one device's configuration at a time. Each application has context-sensitive online help to get you started.
mrahman0302 Wed, 10/29/2008 - 22:28
Hi Joe,
Thanks for your reply. I have used Net Config and Config Editor but my problem is when I want to add certain config on specific device or multiple devices, LMS pushes the whole configuration which I dont want. Let's say I want to add only SSH configuration to specific device or multiple devices, how I can I do that?
Joe Clarke Wed, 10/29/2008 - 22:32
This is what Netconfig is for. Netconfig will only push the config change you want, not the whole config. In fact, Netconfig even includes an SSH task to help you.
