10-29-2008 06:55 PM - edited 03-15-2019 02:15 PM
Hi folks,
Im not able to get inbound callerid working with a 2811 and vic2-2fxo. Im using CME ver7.
I also have a 1751v with vic-2fxo-m1 that is working with callerid.
voice-port 0/0/0
connection plar opx 1001
caller-id enable
10-30-2008 07:07 AM
Caller-id can delivered differently by each carrier, I had a similiar issue and discovered that the telco was using polarity line reversal.
In this scernario, an FXO interface cannot detect line-reversal alerting in the on-hook state.
For this reason, DSPs must be pre-allocated to serve the Type 1 caller ID information when it arrives.
Preallocating the DSPs enables the DSP to continuously monitor for the arrival of caller-ID information.
Configure this command 'caller-id alerting
dsp-pre-alloc' on the FXO port when the incoming subscriber telephone line uses line polarity reversal to signal the start of caller-ID information transmission.
If you debug vpm signal, this should give you an indication in the debug if line-reversal is being used by your telco. Below is a debug example:-
If CLID enabled and line-reversal, the you should see a similar debug as follows:-
Oct 13 14:23:35.263 BST: htsp_process_event: [0/3/0, FXOLS_ONHOOK, E_DSP_SIG_011
0]
Oct 13 14:23:35.263 BST: fxols_line_reversal_clid_wait. Line reversal alerting
Oct 13 14:23:36.375 BST: [0/3/0] htsp_dsm_feature_notify_cb returns 2 id=DSM_FEATURE_SM_CALLERID_RX
Oct 13 14:23:36.375 BST: htsp_process_event: [0/3/0, FXOLS_ONHOOK, E_HTSP_CALLER
ID_RX_DONE]
Oct 13 14:23:37.031 BST: htsp_process_event: [0/3/0, FXOLS_ONHOOK, E_DSP_SIG_000
0]fxols_onhook_ringing
Oct 13 14:23:37.035 BST: htsp_timer - 125 msec
Oct 13 14:23:37.163 BST: htsp_process_event: [0/3/0, FXOLS_WAIT_RING_MIN, E_HTSP
_EVENT_TIMER]fxols_wait_ring_min_timer
Oct 13 14:23:37.163 BST: htsp_timer - 10000 msec
Oct 13 14:23:38.119 BST: htsp_process_event: [0/3/0, FXOLS_RINGING, E_DSP_SIG_01
00]
Oct 13 14:23:38.119 BST: fxols_ringing_not
Oct 13 14:23:38.119 BST: htsp_timer_stop
Oct 13 14:23:38.119 BST: htsp_timer_stop3
Oct 13 14:23:38.119 BST: [0/3/0] htsp_stop_caller_id_rx. message length 29htsp_s
etup_ind
Oct 13 14:23:38.119 BST: [0/3/0] get_fxo_caller_id:Caller ID received. Message t
ype=128 length=29 checksum=63
Oct 13 14:23:38.119 BST: [0/3/0] get_fxo_caller_id calling num=
Oct 13 14:23:38.123 BST: htsp_process_event: [0/3/0, FXOLS_WAIT_SETUP_ACK, E_HTS
P_SETUP_ACK]
Oct 13 14:23:38.123 BST: fxols_wait_setup_ack:
HTH.
Allan
