ASA-5510 ACL host issues
Answered Question
Oct 29th, 2008
I'm trying to give access from host A into the ASA. When I put the ACL in, it gives me a error saying Invalid Hostname. I'm sure the ACL is correct. Not sure if I need to just create a static routing or something else. Here's the ACL's I'm trying to config. Please help. Thanks.
access-list outside_access_in extended permit tcp any host 214.24.3.101 range 15000-15015
Correct Answer by ajagadee about 8 years 3 months ago
Calvin,
I loaded your configuration on one of the lab ASA and the above ACL works just fine.
Can you post the the exact steps from the ASA, along with the errors. Also, make sure that you are in config mode and have authorization to configure the ASA
Arul
Overall Rating: 5 (1 ratings)
calvinz21 Wed, 10/29/2008 - 19:05
here's the current config file.
ASA Version 8.0(3)
hostname asa510-01
domain-name corp.com
enable password xxxxxxxxxxxx encrypted
names
interface Ethernet0/0
nameif outside
security-level 0
ip address 214.x.x.114 255.255.255.240
interface Ethernet0/1
nameif inside
security-level 100
ip address 10.20.1.254 255.255.255.0
interface Ethernet0/2
shutdown
no nameif
no security-level
no ip address
interface Ethernet0/3
shutdown
no nameif
no security-level
no ip address
interface Management0/0
shutdown
no nameif
no security-level
no ip address
ftp mode passive
clock timezone CST -6
clock summer-time CDT recurring
dns domain-lookup inside
dns server-group DefaultDNS
access-list outside_1_cryptomap extended permit ip 10.20.1.0 255.255.0.0 10.0.0.0 255.0.0.0
access-list inside_nat0_outbound extended permit ip 10.20.1.0 255.255.255.0 10.0.0.0 255.0.0.0
access-list outside_access_in remark allow public to http
access-list outside_access_in extended permit tcp any host 214.24.29.115 eq www
pager lines 24
logging enable
logging buffered debugging
logging asdm informational
logging host inside 10.1.xx.xx
mtu outside 1500
mtu inside 1500
ip verify reverse-path interface inside
icmp unreachable rate-limit 1 burst-size 1
icmp permit any inside
arp timeout 14400
global (outside) 1 interface
nat (inside) 0 access-list inside_nat0_outbound
nat (inside) 1 10.20.1.0 255.255.255.0
static (inside,outside) 214.24.29.115 10.20.1.10 netmask 255.255.255.255
access-group outside_access_in in interface outside
route outside 0.0.0.0 0.0.0.0 214.24.29.113 1
timeout xlate 3:00:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 icmp 0:00:02
timeout sunrpc 0:10:00 h323 0:05:00 h225 1:00:00 mgcp 0:05:00 mgcp-pat 0:05:00
timeout sip 0:30:00 sip_media 0:02:00 sip-invite 0:03:00 sip-disconnect 0:02:00
timeout uauth 0:05:00 absolute
dynamic-access-policy-record DfltAccessPolicy
aaa-server LIST1 protocol tacacs+
key xxxxxxxxx
aaa authentication http console LOCAL
aaa authentication ssh console LOCAL
aaa accounting enable console LIST1
http server enable
http 10.20.10.0 255.255.255.0 inside
http 207.40.115.253 255.255.255.255 outside
snmp-server host inside 10.1.11.45 community 1232344
snmp-server location xxxxxxxx
no snmp-server contact
snmp-server community 123cabaf3a
snmp-server enable traps snmp authentication linkup linkdown coldstart
crypto ipsec transform-set ESP-3DES-SHA esp-3des esp-sha-hmac
crypto map outside_map 1 match address outside_1_cryptomap
crypto map outside_map 1 set pfs
crypto map outside_map 1 set peer 207.40.115.1
crypto map outside_map 1 set transform-set ESP-3DES-SHA
crypto map outside_map interface outside
crypto isakmp enable outside
crypto isakmp policy 10
authentication pre-share
encryption 3des
hash sha
group 2
lifetime 86400
console timeout 5
management-access inside
threat-detection basic-threat
threat-detection statistics
tunnel-group 207.40.115.1 type ipsec-l2l
tunnel-group 207.40.115.1 ipsec-attributes
pre-shared-key *
class-map inspection_default
match default-inspection-traffic
policy-map type inspect dns preset_dns_map
parameters
message-length maximum 512
policy-map global_policy
class inspection_default
inspect ftp
inspect netbios
inspect rsh
inspect rtsp
inspect esmtp
inspect sqlnet
inspect tftp
inspect xdmcp
inspect http
inspect icmp
inspect snmp
service-policy global_policy global
prompt hostname context
calvinz21 Thu, 10/30/2008 - 07:49
I did try it with just a port and still giving the same error. ex:
access-list outside_access_in extended permit tcp any host 214.24.3.101 eq 8400
Curious, does it have something to do with that fact that it's almost on the same subnet or the first 2 sets of IP's are the same?
Correct Answer
ajagadee Thu, 10/30/2008 - 11:36
Calvin,
Arul
calvinz21 Thu, 10/30/2008 - 11:52
ajagadee,
I swear to god. I did the same thing yesterday and it was not taking it at all. The acl's went in fine today. Thanks for your help.
ajagadee Thu, 10/30/2008 - 12:10
Calvin,
Thanks for the update! Glad to know it works.
Arul
