10-29-2008 09:24 PM
I have configured the netflow on our switches according to the configuration guide from cisco wensite, and this is my config:
mls netflow
mls flow ip interface-full
ip flow ingress layer2-switched vlan 25,48
mls nde sender version 5
interface Vlan25
ip address 10.122.25.15 255.255.255.0
ip flow ingress
ip route-cache flow
interface Vlan48
ip address 10.122.48.201 255.255.255.0
ip flow ingress
ip route-cache flow
ip flow-export source Vlan25
ip flow-export version 9
ip flow-export destination x.x.x.x 9991
I can find the data been collected by the server on which cisco Netflow Collector has been installed, and I can generate report, but only show us the simple result such as: source
Ip and destination IP.
If we change to generate report based on protocol, it always gave us error message: no protocol data from result file.
10-29-2008 09:28 PM
i post my to result as well:
XXXXXXXX#sh mls netflow ip
Displaying Netflow entries in Supervisor Earl
DstIP SrcIP Prot:SrcPort:DstPort Src i/f :AdjPtr
Pkts Bytes Age LastSeen Attributes
1 60 95 12:20:39 L2 - Dynamic
10.122.48.39 10.122.25.15 icmp:0 :0 Vl48 :0x0
28 3360 1867 12:21:07 L2 - Dynamic
0.0.0.0 0.0.0.0 0 :0 :0 -- :0x0
23 1058 61 12:22:01 L3 - Dynamic
10.122.48.39 10.122.25.15 udp :161 :33311 Vl48 :0x0
573 188526 646 12:21:32 L2 - Dynamic
10.122.48.39 10.122.25.15 udp :49849 :9996 Vl48 :0x0
18 13052 206 12:22:02 L2 - Dynamic
10.122.48.39 10.122.25.15 udp :49852 :9996 Vl48 :0x0
0 0 331 12:20:42 L2 - Dynamic
XXXXXX#sh ip cache flow
MSFC:
IP packet size distribution (19036 total packets):
1-32 64 96 128 160 192 224 256 288 320 352 384 416 448 480
.000 .011 .478 .168 .011 .071 .033 .010 .012 .002 .015 .000 .000 .002 .000
512 544 576 1024 1536 2048 2560 3072 3584 4096 4608
.000 .150 .020 .009 .000 .000 .000 .000 .000 .000 .000
IP Flow Switching Cache, 4456704 bytes
6 active, 65530 inactive, 1381 added
36853 ager polls, 0 flow alloc failures
Active flows timeout in 30 minutes
Inactive flows timeout in 15 seconds
IP Sub Flow Cache, 270664 bytes
6 active, 16378 inactive, 1713 added, 1381 added to flow
0 alloc failures, 0 force free
1 chunk, 2 chunks added
last clearing of statistics never
Protocol Total Flows Packets Bytes Packets Active(Sec) Idle(Sec)
-------- Flows /Sec /Flow /Pkt /Sec /Flow /Flow
TCP-other 22 0.0 4 45 0.0 0.3 1.4
UDP-other 1200 0.0 15 189 0.0 12.6 15.4
ICMP 153 0.0 1 97 0.0 0.0 15.4
Total: 1375 0.0 13 187 0.0 11.0 15.1
SrcIf SrcIPaddress DstIf DstIPaddress Pr SrcP DstP Pkts
Vl48 169.254.150.182 Null 169.254.255.255 11 0089 0089 6
Vl48 10.122.48.52 Null 10.122.48.255 11 0089 0089 6
Vl48 10.122.48.13 Null 10.122.48.255 11 0089 0089 3
Vl48 10.122.48.14 Null 10.122.48.255 11 0089 0089 3
Vl48 10.122.48.15 Null 10.122.48.255 11 0089 0089 6
Vl48 169.254.213.60 Null 169.254.255.255 11 0089 0089 6
PFC:
Displaying Hardware entries in Module 1
SrcIf SrcIPaddress DstIPaddress Pr SrcP DstP Pkts
Vl25 10.122.25.37 10.122.48.42 udp 161 34381 1
Vl25 10.122.25.39
