Upgradation of flash
Oct 29th, 2008
While upgrading Flash on router it goes into rommon mode. How can I back into router mode?
I use command confreg 0x2101 and reset but int again goes into rommon mode.
Please help.
kalshetty Wed, 10/29/2008 - 23:01
It saying that Input redirection is not supported at this level.
bagvanliju Thu, 10/30/2008 - 00:31
Hai,
Are you sure that ios is transferd sucfly to Flash ..?? if so ...
...when are you getting this error ???
rommman>confreg 0x2102
romman> reset
ujil
kalshetty Thu, 10/30/2008 - 03:46
Hi Ujil,
When I set the configuration register to 0x2102. And then set the boot path from the rommon using " BOOT:=bootflash:,
it gives that error.
And how I know that ios is transferd sucfly to Flash?
When I put command dev it shows flash but I put command dir flash it shows error that bad device name.
bagvanliju Thu, 10/30/2008 - 04:10
hai,
I suspect ios is not properly tranfrd ,,,,can u try uploading the ios once again ...via console and see the status ....
Guys correct me if i am wrong
ujil
patrickvanham Thu, 10/30/2008 - 04:28
rommon mode is a bit more sensitive than the IOS prompt. try using "dir FLASH:" (without quotes). Redirect implies you actually use "" when using boot. Is this assumption correct?
kalshetty Thu, 10/30/2008 - 20:20
When I put the command dir flash, it shows error that bad device name.
I think router's flash is corrupted.
Pleae educate me on this issue.
kalshetty Thu, 10/30/2008 - 23:29
Thanks. It's done by downloading a software image via TFTP using the tftpdnld ROMMON ommand.
