UC500
Answered Question
Oct 29th, 2008
Do we need specific licenses for what type of phones we can use with UC500, like 7940, 7960 and so on, or any phone type is supported and the general license covers everything.
For example:
UC520W-8U-4FXO-K9 supports 8 phones, can these phones be any type?
Cheers
Correct Answer by Rob Huffman about 8 years 8 months ago
Hi Hadi,
First off, you are most welcome :)
Here are some related links. You will find the SBCS - Wiki extremely useful;
Cisco Smart Business Communications System Teleworker Setup
http://www.cisco.com/en/US/docs/voice_ip_comm/sbcs/hardware/quick/guide/uc5_tele.html
SBCS:Documentation - Cisco Smart Business Communication Systems - Ciscowiki
http://supportwiki.cisco.com/ViewWiki/index.php/Category:Documentation_-_Cisco_Smart_Business_Communication_Systems
Hope this helps!
Rob
Overall Rating: 5 (4 ratings)
Sushil Kumar Katre Wed, 10/29/2008 - 22:55
  • Gold, 750 points or more
Hi Hadi,
As far as I know you don't require any specific license for the type of phones you are going to use.
Please wait for confirmation from other members, since I am not 100% sure and never ordered UC500.
-> Sushil
Rob Huffman Thu, 10/30/2008 - 06:03
  • Super Red, 40000 points or more
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 IP Telephony, Unified Communications
Hi Hadi,
My friend Sushil is most correct :) (+5 points buddy!)
When you order a pre-configured UCS 5XX is does come with all applicable Licensing (including IP Phone licenses).
Have a look at this as well;
Various fixed configurations are offered, eliminating the guesswork from configuration.
Each configuration is equipped with the appropriate number of feature licenses for call processing, voicemail, and Cisco Unified IP phones, simplifying the product structure.
For example;
UC520-8U-2BRI-K9
8 User configuration with 2 BRI trunks (BRI), 4 Analog ports (FXS), 8 PoE ports, 1 VIC slot for expansion
Feature licenses for call control, voicemail and **Cisco Unified IP Phones
Or
UC520W-8U-4FXO-K9
8 User configuration with 4 PSTN trunks (FXO), 4 Analog ports (FXS), 8 PoE ports, 1 VIC slot for expansion, Integrated Wi-Fi Access Point
From this good UCS 500 doc;
http://www.cisco.com/en/US/products/ps7293/products_data_sheet0900aecd8061fb06.html
Hope this helps!
Rob
hadisharifi Thu, 10/30/2008 - 15:16
Thanks guys and appreciate your help, I have another question though. What is a teleworker? example the 8 and 16 user support version of UC500 support 2 teleworkers. Is this remote users with soft phones? I am a bit confused here as to whether it's the number of soft phone support or something else.
Hadi
Correct Answer
Rob Huffman Thu, 10/30/2008 - 15:51
  • Hall of Fame,
    Founding Member
Hi Hadi,
Hope this helps!
Rob
