ASA 5550 restart suddenly
Oct 30th, 2008
Dear all,
kindly show me what could be the cause of ASA5550 restarted suddenly. and where can I see the logs of it and how to rectify.
thanks & regards,
Overall Rating: 5 (1 ratings)
francisco_1 Thu, 10/30/2008 - 01:26
If a firewall crashes for some reason, you might be left with few clues other than it reloaded or was left at the monitor prompt. You can configure the firewall to save a crashinfo image of its RAM memory as a file in Flash memory. The image also includes the output of many commands that show the status of the firewall and its resources. A firewall stores only one crashinfo file; subsequent crashes overwrite it. Therefore, only information from the most recent crash is available.
After a crash, you can examine the crashinfo file to determine the cause of the crasheven after a power cycle or reload. This information is useful to the engineers at the Cisco Technical Assistance Center (TAC) as they track down the source of a firewall problem.
By default, crashinfo collection is enabled on cisco ASA's firewall.
Viewing the Crashinfo Information
ciscoasa# "show crashinfo"
The show crashinfo command displays all the relevant process and stack trace information that was active during the crash. You should capture all this text output with a terminal emulator so that it can be saved to a file and sent to Cisco TAC. if you upload it i might find out why it creashed. also post the show version as well.
Francisco.
zakid Thu, 10/30/2008 - 03:53
Dear
Many thanks..... I will follow the steps, meanwhile i was monitoring the cpu usage its from 85 - 98 percentage, i never seen before.
this could be the reason. secondly, current IOS is 7.2.2, if I upgrade to 8.0 or later It would solve my CPU usage.
thanks.
francisco_1 Thu, 10/30/2008 - 07:07
might be. our ASA's crashed few wks ago due to a memory issue. code affected was 7.2(13). we upgarded to 8.0.
Francisco.
