reg:router
Oct 30th, 2008
Dear sir,
I m looking for a Load Balancing Router with 4 WAN Ports(rj45) and 1 LAN port . I need to merge Four 1MBPS lines and i need output speed as 4MBPS .
plz suggest me which mode is better.
srini
satish_zanjurne Thu, 10/30/2008 - 01:03
  • Silver, 250 points or more
It will be good if you use L3 switch like WS-C3750G-24TS-E ( enhanced multilayer image).
Use port channel to bind all 1 mbps links.
This gives you LAN connections also.
HTH...rate if helpful..
patrickvanham Thu, 10/30/2008 - 02:07
The RJ45 ports, exactly what kind of ports are they? Serial? (gig/fast)Eth?
Amit Singh Thu, 10/30/2008 - 02:40
  • Cisco Employee,
Srini,
are these links coming from the same ISP? are they going to the same site ? Are these E1 ports using the G.703 MFT E1 interfaces ?
-amit singh
