Hi Elias ,
Kindly check on inside interface first with following commands & then check for outside interface.
snmp-server enable
snmp-server host inside 192.168.3.2
snmp-server community key
snmp-server enable traps all
Also addd
logging enable
The default configuration has all snmp traps enabled.
HTH..rate if helpful..
