Per-packet load-sharing over Multilink PPP
rvr_76bg
Hello guys,
I want to enable per-packet load-sharing on my 2800 Router. I have 2 xT1 combined in a Multilink PPP. I am wondering where I have to enable per-packet load-sharing on the Multilink Interface or on both T1/s interfaces bundled in a single Multilink. Thank you in advance.
rvr
Yes, that's what the multilink PPP would do bydefault. It will try to do a best effort per-packet load-sharing on both the links but you cannot explicitly configure the per-packet load-balancing on the interfaces which are a part of the MLPPP bundle.
HTH,
-amit singh
Amit Singh
RVR,
No you cannot have per-packet load-balancing enabled on the bundled MLPPP links. In your case if you're configuring Multilink PPP to bundle the T1's together then the serial links are logically tied to the Virtual Multilink interface and you cannot do per-packet load balancing.
If you disable Multilink PPP you can configure per-packet load balancing. Basically, the per-packet load-balancing can only be done on an interface that has an ip address. If you configure Multilink PPP the ip address is only assigned to Multilink interface and not individual interfaces.
HTH,Please rate if it does.
-amit singh
Excellent reply! I saw a doc that said Multilink interface performes per-packet load-sharing by deafult. When a packet has to be send over the bundled lines MLPPP will send one packet to the first then second to the other line (case with 2 lines combined).
rvr
HTH,
-amit singh
Thank you very much.
rvr
