Selecting non-crypto IOS devices
Oct 30th, 2008
Our more than 1500 devices are managed by LMS. Most of them use crypto IOS but some of them don't. How can i select from inventory ( report or group selection ) the devices which do not use crypto IOS.
We have to upgrade them and introduce the SSH to its.
Thanks in advance!
Overall Rating: 5 (1 ratings)
Joe Clarke Thu, 10/30/2008 - 07:07
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
You can build a user-defined group in RME for this. For example, to match IOS devices which are running non-crypto images, this ruleset should work:
Device.Image.Sys_Description contains "IOS" EXCLUDE
Device.Image.Sys_Description contains "k9"
KAROLY KOHEGYI Thu, 10/30/2008 - 07:32
Thanks. It is usable mainly for routers.
The following IOS description of 2950 switch is the following.
c2950-i6k2l2q4-mz.121-22.EA9.bin
it's crypto IOS. May be does "k" mean the crypto??
Joe Clarke Thu, 10/30/2008 - 07:34
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
Yes, images with a 'k' (usually "k9") indicates crypto.
The problem is, the description can contain another 'k', and the image may not be a crypto image. You can try just matching on 'k', but you may have to tweak things if you get a false-positive.
KAROLY KOHEGYI Thu, 10/30/2008 - 07:40
Yes,yes it is my problem.
If it is possible please develop this filter possibilty in the RME or LMS in the following patch. :-)
Thanks!
Joe Clarke Thu, 10/30/2008 - 07:50
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
You can make this request through your account team. They can open a PERS (Product Enhancement) request on your behalf.
Joe Clarke Thu, 10/30/2008 - 07:58
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
You can also try this pattern which should properly match more non-crypto IOS devices:
Device.Image.Sys_Description contains "k9" EXCLUDE
Device.Image.Sys_Description contains "k2" EXCLUDE
Device.Image.Sys_Description contains "k8"
KAROLY KOHEGYI Thu, 10/30/2008 - 08:05
Thanks for your effort.
i will look for the all alternative.
