How to configure NO NAT on ASA 5520, this is urgent!!
Oct 30th, 2008
I have an ASA5520 which is to be deployed in out internal network and the following subnets are configured..
outside -> 10.1.127.0 -> security level 0
inside -> 10.1.110.0 -> security level 100
We want the firewall to work more as a router only with no nat configuration at the same time the source & destination address should be able to ping each without compromising on security.
Syed
cisco24x7 Thu, 10/30/2008 - 04:26
no nat-control.
access-list outside permit ip any any log
access-group outside in interface outside
Now you have a router.
csco11049253 Thu, 10/30/2008 - 04:31
Is there any need to add configuration related to NAT ex..
nat (inside) 0 0.0.0 0.0.0.0.0 ???
Syed
csco11049253 Thu, 10/30/2008 - 04:46
I've done what you've suggested but still I can ping the other networks.
Syed
cisco24x7 Thu, 10/30/2008 - 05:04
post your config.
You must have other NATs on
the ASA. Once you enable PAT or STATIC NAT,
"no nat-control" becomes useless.
