CUE system prompt
Answered Question
Oct 30th, 2008
Does someone know if it is possible to edit/change the default prompt of CUE 3.2 ?
For instance, change the "please record after the tone".
Thx
Fabian
Correct Answer by Markus Schneider about 8 years 6 months ago
You can only enable or disable the playing of that prompt via the command:
voicemail conversation caller recording-prompt
http://www.cisco.com/en/US/docs/voice_ip_comm/unity_exp/rel3_2/administrator/voicemail/3VMpara.html#wpmkr1012072
Overall Rating: 5 (1 ratings)
