Nested QoS
Oct 30th, 2008
  • Silver, 250 points or more
Hi guys,
looking for a little confirmation on this one.
class-map match-all CUST1
match access-group 12
class-map match-all CUST2
match access-group 11
class-map match-all CUST3
match access-group 10
policy-map GUARANTEE
class CUST1
bandwidth 4000
class CUST2
bandwidth 4000
class CUST3
bandwidth 2000
policy-map MAX10MBPS_NESTED
class class-default
shape average 10000000
service-policy GUARANTEE
interface FastEthernet0/0
service-policy output MAX10MBPS_NESTED
I am applying this policy outbound on a WAN router. I want one custome to have 2Mb and the other two to have 4 Mb guarunteed. Then i wan to limit all to 10 Mbps Max. Is this policy correct.
Stephen
Joseph W. Doherty Thu, 10/30/2008 - 05:02
Looks good, except . . .
Do note, you're shaping overall traffic at 10 Mbps and your 3 defined classes add up to 10 Mbps, but policy GUARANTEE has an implicit class-default. Any traffic in that class will also compete for your 10 Mbps so it's possible your other classes won't always get the bandwidth you intend. However, assuming only control traffic falls into the class-default, it shouldn't be anything to worry about. But if there were unknown CUST4 traffic, it might be.
stephen.stack Thu, 10/30/2008 - 05:21
Hi Joesph,
Thanks for response. This makes sense. In future there will be a CUST4 and then some. What do you think i shoul;d do here, if the first three need to have guaruntees and then be limited to 10 Mbps. While additional customers have access to the rest of the bandwidth.
Thanks Again
Stephen
Joseph W. Doherty Thu, 10/30/2008 - 06:09
Not enough information to suggest what you should do, since I don't know what you really want to accomplish.
However, if we suppose customers are buying some allocation of bandwidth, you can move them up a level in the main policy and define both a minimum bandwidth and max.
Assuming you're working off a 100 Mbps:
class CUST1
bandwidth 4000
shape average 4000000
class CUST2
bandwidth 4000
class CUST3
bandwidth 2000
shape average 2000000
service-policy output GUARANTEE
You could also expand the above, I believe, to use a child policy to allow the customer different levels of service within their bandwidth.
policy-map ServiceLevels
class real-time
priority percent 20
class gold
bandwidth remaining percent 50
class silver
bandwidth remaining percent 35
class class-default
bandwidth remaining percent 15
class CUST1
bandwidth 4000
service-policy ServiceLevels
class CUST2
bandwidth 4000
class CUST3
bandwidth 2000
You'll need to fill in the blanks for what matches against the different classes.
Also note, there is a limit to how many classes you can define (older IOSs was 64 now 256?).
stephen.stack Wed, 11/05/2008 - 10:23
Hi Joesph,
Thanks for updtae, and i'm sorry it took so long to get back to you. (Been snowed under).
I have implemented you first solution, whoch seems to work a treat. This way we have a 100Mb link and we can guaruntee amounts of bandwidth while allowing customers to burst to specified limits.
Stephen
