Rob Huffman Thu, 10/30/2008 - 05:56
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 IP Telephony, Unified Communications
Hi Ammar,
This upgrade *** will require you to order the Media Kits and License via PUT. It looks like you are trying the downlaod file which is not a supported method for this upgrade;
Upgrade Paths To Cisco Unified Communications Manager 6.1(2)
You can upgrade directly to Cisco Unified Communications Manager 6.1(2) from:
•4.2(3x)
•5.1(2x)
•5.1(3x)
•6.0(1a)
•6.1(1x)
Caution: Use the ISO files that are mentioned in the "Upgrading from Cisco Unified Communications Manager Release 6.0.(1a) or higher to Release 6.1(2) by Using the UCSInstall File" section for upgrades from 6.1(1x)only.
Upgrading from Unified CM 4.x and 5.x
***If you are upgrading from 4.1.3, 4.2.3, 5.1.1, 5.1.2, or 5.1.3, use the Product Upgrade Tool (PUT) or the PUT that is for registered customers only to obtain a media kit and license or to purchase the upgrade from Cisco Sales.
To use the PUT, youmust enter your Cisco contract number (Smartnet, SASU or ESW) and request the CD/CD set. If you do not have a contract for Cisco Unified Communications Manager, you must purchase the upgrade from Cisco Sales.
For more information about supported Unified CM upgrades, see the Cisco Unified Communications Manager Compatibility Matrix at the following URL:
http://www.cisco.com/en/US/products/sw/voicesw/ps556/products_device_support_tables_list.html
From these good release notes;
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/rel_notes/6_1_2/cucm-rel_note-612.html#wp396032
Hope this helps!
Rob
