Fax relay features VG224
Oct 30th, 2008
Hi UC experts,
I have a question. Is it possible to set the fax relay mode to t38 for a specific vg224 port configured via sccp.
In the cisco documentation I found: "Standards-based T.38 fax for VoIP - T.38 has been available in Cisco IOS Software Releases 12.1(3)T and later on some platforms. It can be enabled with the fax relay protocol t38 command configured under the VoIP dial peer and uses UDP to transport fax data."
http://www.cisco.com/en/US/tech/tk652/tk777/technologies_tech_note09186a0080114565.shtml#topic2-4
I tried to find the command with 124-15.T5 under the voice-ports and dial-peers but no chance. There is only the global command for the whole GW under "voice service voip".
Thanks and regards
Moe
