10-30-2008 05:28 AM
I've setup a SIP probe to check the health of a Microsoft OCS. The health of this server is always failed. What am I missing? I also tried it with a telnet probe on port 5061, but got the same result. A telnet from ACE to the server on port 5061 works fine.
See below a show probe SIP detail and the relevant configuration.
ACE21_Secondary/MOCS# sh probe SIP det
probe : SIP
type : SIP
state : ACTIVE
description :
port : 5061 address : 0.0.0.0 addr type : -
interval : 10 pass intvl : 10 pass count : 3
fail count: 3 recv timeout: 4
request-method : OPTIONS
conn termination : GRACEFUL
expect offset : 0 , open timeout : 2
expect regex : -
------------------ probe results ------------------
associations ip-address port porttype probes failed passed health
rserver : OCS_11
10.105.11.70 5061 -- 7566 7566 0 FAILED
Socket state : CLOSED
No. Passed states : 0 No. Failed states : 0
No. Probes skipped : 0 Last status code : 0
No. Out of Sockets : 0 No. Internal error: 0
Last disconnect err : Server reply timeout (no reply)
Last probe time : Thu Oct 30 14:18:42 2008
Last fail time : Tue Oct 28 16:31:30 2008
Last active time : Never
ACE21_Secondary/MOCS# sh run
probe sip tcp SIP
port 5061
interval 10
passdetect interval 10
receive 4
expect status 200 200
open 2
rserver host OCS_11
ip address 10.105.11.70
probe SSL
probe PING
probe SIP
probe SIP_TELNET
inservice
Cheers
Peter
11-04-2008 05:55 AM
Peter,
make sure to NOT run version A2(1.1a) as SIP probes are broken in that specific release.
If your version is something else, get a sniffer trace on the server to see what is going on.
Seems like we don't get a reply according to the line :
"Last disconnect err : Server reply timeout (no reply) "
Gilles.
