Dial Extn at anytime in default AA of CUE?
Answered Question
Oct 30th, 2008
Hi all,
How do I config the default aa.aef of CUE so the callers can dial extension at anytime, or press 0 for operator? Or how to customize a custome AA to do this?
my CUE version is :
CUE# show software versions
Installed Packages:
- Installer 2.2.1
- Thirdparty 2.3.2
- Bootloader (Primary) 2.1.2
- Infrastructure 2.3.4
- Global 2.3.4
- Service Engine license 1.20 2.1.2
- Auto Attendant 2.3.0
- Voice Mail 2.3.2
- Bootloader (Secondary) 2.1.2
- Core 2.3.4
- GPL Infrastructure 2.3.0
Installed Languages:
- English language pack 2.3.0
Thanks in advanced!
Correct Answer by Brandon Buffin about 8 years 9 months ago
Take a look at the attached script. It enables callers to dial during the opening greeting as well as several other useful features. You will need to modify it to fit your environment, but it should give you a good start.
Hope this helps.
Brandon
Overall Rating: 5 (1 ratings)
Correct Answer
Brandon Buffin Thu, 10/30/2008 - 06:44
  • Purple, 4500 points or more
Hope this helps.
Brandon
huydien3384 Thu, 10/30/2008 - 07:21
wow, I dont know how to say thanks to you Brandon, it's really great!
Thank you very much! :) :)
