5.0 UM to VM with Exchange 2003
Answered Question
I have a client that does not want to buy a Exchange Cal license for there VM users.
Currently they have about 500 users installed on a Unified Exchange 2003 Server. They want to move 370 users to a VM runtime Exchange server.
I have seen the white paper for Mixed license and it states:
How to Set Up a Cisco Unity Configuration to Support a Mixed VM/UM License:
Segmenting Voice Messaging Subscribers
To allow for careful management of Voice Messaging subscribers, we recommend doing one of the
following:
• Exchange only-Dedicate a storage group on one or more Exchange servers that houses all Voice Messaging subscribers.
My question is can I just create a storage group on the UM exchange server for the VM users?
What are the steps for doing this?
Permissions Wizard?
Greg Nystrom
Correct Answer by Chris Deren about 8 years 8 months ago
You cannot, you need to create new accounts, as the old ones are unified and are referenced by the email as well. To seperate UM from VM doing the COS change is not enough, you still need to seperate email mailbox from VM mailbox, hence creating new AD user with new Exchange mailbox. Typically the VM accounts are called somthing like vm-alias.
Chris
Overall Rating: 5 (2 ratings)
Chris Deren Thu, 10/30/2008 - 06:49
  • Hall of Fame,
  • Cisco Designated VIP,
    2017 IP Telephony, Contact Center, Unified Communications
You don' really need a seperate storage group, unless you want to. You can simply create new AD users/Exchange mailboxes in the same mailstore, you can either do this via Unity if you have sufficient right allocated or create these users/mailboxe ahead of time and import in Unity. Make sure you specify the COS as VM rather than UM in Unity when building these subscribers.
Chris
Correct Answer
Chris Deren Thu, 10/30/2008 - 08:12
  • Hall of Fame,
Chris
Thanks Chris,
One more question when creating a VM mailbox with Unity Exchange 2003 does that require a M$ CAL.
I see no difference with the VM mailbox vs UM mailbox. M$ defines a CAL as a mailbox. I know that MS is on the honor system for Exchange but my client does not want a audit and come up short.
-G
Chris Deren Thu, 10/30/2008 - 11:51
  • Hall of Fame,
No, the CAL cost is built into the Unity user license.
HTH,
Chris
safety2008 Thu, 10/30/2008 - 06:53
Greg,
We did and still use this type of app. we did create a seperate store and use alias of vm-xxxxxxx/user in unity. I am not our exchange guru, and he is out today but i can ask him what we did. i dont think we used the wizard as we found it sometimes useless.and all vm- accts are in that store in xchange.
