Hunt groups?
Oct 30th, 2008
Setting up hunt groups in callmanager. I am used to a siemens setup, in that when a HG is dialed it will keep cycling through until picked up. in CM it seems to hit each member once, then disconnect. it is circular with rule of try next member but not next group. Just trying to verify that is correct.
Thank you.
Rob Huffman Thu, 10/30/2008 - 07:05
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 IP Telephony, Unified Communications
Hi Stanley,
That is working as expected. You can however set up a second Line Group that contains the same DN's/Members and link this second Group in the Hunt List.
Switch the rule on the first Line Group to, Try next Member;then try next Group in Hunt List
This will then cycle through the members a second time (I just tested this out in our lab) :)
Hope this helps!
Rob
Rob Huffman Thu, 10/30/2008 - 07:29
  • Hall of Fame,
    Founding Member
Hi Stanley,
You are most welcome! Glad to be of some help.
Cheers!
Rob
