Warning message
Route Map Problem
Oct 30th, 2008
We have tow ISP links terminated on two routers WAN ports ( 1841 series). And the ethernet both the routers and the outside of the ASA are from a single subnet. ( a.b.c.0 / 24 ). Since the tow ISP's has given us a totally seperate pool of IP address we need to route the corresponding IP packet to the corresponding ISP routers. Policy based IP routing ( in this case source based for the packet going to outside world from ASA ) is not supported in ASA and we are required to use route map.
ASA has a default route to ISP-1 router ethernet. But when packet is having the source IP address from from the ISP-2 pool it shoud be sent to ISP-2 router.
I did the following configuration
on ISP-1 router:-
access-list 101 permit ip host P.Q.R.S ( IP address from the ISP-2 pool)
route map ISP2
match access-group 101
set next-hop ISP-2_router_Eth_ADDRESS
conf t
int fast0/0 ( ISP1 router interface)
ip policy route-map ISP2
With this packets with source IP with P.Q.R.S will be sent to ISP-2 router ethernet port and the remaining packets will be routed by default to WAN link that is ISP-1 WAN link.
But some how this doesnt seem to work I checked out for the access-list hit count there are not hits.
What is going wrong?
Please share your experience for route maps or terminating two ISP on a single ASA. Inputs are appreciated.
Thanks in advance
Subodh
Richard Burts Thu, 10/30/2008 - 07:30
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
Subodh
In your post you give access list 101 as:
but an extended access list should have a source address and a destination address. You have given only a single address. This may be the source of your problem.
Also it is not clear to me from your post whether the int fast0/0 is the interface which faces the firewall or whether it faces the ISP. The route map needs to be applied on the interface which faces the firewall.
[edit] Also I notice that you describe it as a pool for ISP 2 but your access list is specifying only a single address. Perhaps this is also part of the problem.
Rick
bapatsubodh Thu, 10/30/2008 - 07:52
Ya ,
access list 101 ends with any ,
That means permit with source P.Q.R.S to any IP address on the internet.
Secondly we are using only one IP address from the ISP-2 pool that is P.Q.R.S hence I have used only one IP addrss as source IP.
And also fast 0/0 is the routers ASA facing interface.
ISP-2-LAN and ISP-1-LAN and ASA-Outside interface are in the same subnet and can ping to each other. I have added this policy routing on the ISP-1 router fast0/0.
Is there any way to test if this router map is being hit by packets?
I did :
debug ip packet 101 I was expecting a fireworks on console but i didnt see any thing. I am missing out some thing some where
Just not able to debug !!
