Help! blocking incoming calls
Answered Question
Hi all,
At a customer site trying to block incoming calls and am running into issues.
the code is h323 and all calls work fine inbound and out bound.
I applied the following to the router, am i missing something? I want to be able to block certain incoming numbers
voice translation-rule 1
rule 1 reject /9195236831/
rule 2 reject /^9195236831/
voice translation-profile reject
translate calling 1
voice-port 0/0/0:23
translation-profile incoming reject
Correct Answer by Jaime Valencia about 8 years 8 months ago
it should be
call-block translation-profile incoming reject
Refer to the documentation for further explanation
Reject Calls
http://www.cisco.com/en/US/partner/tech/tk652/tk90/technologies_tech_note09186a0080325e8e.shtml#reject
Call Blocking Configuration Examples
http://www.cisco.com/en/US/customer/tech/tk652/tk90/technologies_configuration_example09186a00803f818a.shtml#con11
java
if this helps, please rate
Overall Rating: 5 (1 ratings)
Correct Answer
Jaime Valencia Thu, 10/30/2008 - 09:35
  • Cisco Employee,
  • Hall of Fame,
    2011
it should be
Reject Calls
java
