Cisco asa 5510 lost connection
Oct 30th, 2008
Good morning:
I have some problems with my firewall, some times i lose connection between it and some servers.
Adjunt the network diagramn.
A partner work, tell me that this can be a routing problem.
The servers have the Firewall how default gateway.
Some somebody help me.
Thank's in advanced.
jasosan22 Thu, 10/30/2008 - 12:54
you can enable logging on the asa. check the logs. look for errors on the interface. what's the config on the core?
colonha27 Fri, 10/31/2008 - 09:19
The ASA have enable logs , and i dont see errors in the interfaces.
What information you need for the CORE?
jasosan22 Fri, 10/31/2008 - 19:35
Can you put a sniffer on the core? or plug the devices that are dropping packet directly into the the ASA?
