10-30-2008 08:22 AM - edited 03-06-2019 02:13 AM
Is it possible to configure SPAN destination port in a way that system on that port can be accessed from outside as well? By the i am using 3560 with IP services image.
Thanks in advance.
10-30-2008 10:04 AM
You can use the ingress keyword along with the destination port configuration to allow the traffic on to the connected system.
HTH, Please rate if it does.
-amit singh
10-30-2008 11:17 AM
What we do is attach 2 nics to the host device, this way the host can say be running Wireshark and we access the host through the other nic on the LAN.
HTH,
Brandon
10-30-2008 09:29 PM
I'd have to agree with Brandon. You generally don't want to capture both the SPAN traffic and your normal traffic. It is MUCH better to keep them separated.
Paul
