routing policy ip reachability
Oct 30th, 2008
I am looking to set up a ip reachability policy. I have never dont it before and am looking information on it either by you telling me or someone showing me were good documintation is on this.
Chris
sgtbilko711 Thu, 10/30/2008 - 10:10
Jon
Ok it looks right but let me run this by you.
If i have traffic going out one ip interface on a router and i have the 6500 check to see if it is up. whn it goes down i want to send it to a new ip interface.
looking over the doc. it looks like it but i am not sure.
Amit Singh Thu, 10/30/2008 - 10:27
  • Cisco Employee,
Here is a test config that I had setup to check the same stuff. The toplogy that I used was like R1 --> R2 and R3 and both R2 and R3 inturns connect back to R4.
R2-----
R1--- R4
R3-----
The test was to use IPSLA and object tracking to fail-over the traffic from R1 to either of the connection in case of an indirect failure in the connectivity. I was pinging the R4 loopback addresses from R1 and tried shutting down the R2 and R3 link to R4.
HTH, Please rate if it does.
-amit singh
