Warning message
Sup2 module replacement procedure help
Oct 30th, 2008
I have only one sup2 module in my switch running catos and i want to replace this with teh new sup2 module. Can someone plz give me the cisco link about the procedure to do the same.
As per my knowledge here are the steps:-
1) Backup the config
2) switch off the cat 6500
3) remove the sup module
4) insert the new sup module
and reboot it....
Kindly let me know if this is correct procedure or do i have to look at any other things.
THanks in advance.
Neha
jasosan22 Thu, 10/30/2008 - 12:49
When you say the new Sup 2 module are you going to IOS? What model numbers are your sup modules?
