1760 WIC-1Enet subinterface support
Answered Question
Oct 30th, 2008
Hi All,
Does anyone know if subinterfaces and VLAN encapsulation is supported on a WIC-1Enet card in a 1760? If so which IOS version/feature set is required?
Many Thanks
Scott
Correct Answer by Collin Clark about 8 years 7 months ago
Scott-
It's not supported, you must have a fast ethernet interface.
Hope that helps.
Overall Rating: 4 (1 ratings)
Correct Answer
Collin Clark Thu, 10/30/2008 - 10:17
  • Purple, 4500 points or more
Scott-
Hope that helps.
scottwilliamson Fri, 10/31/2008 - 01:55
Hi Collin,
That's what I was thinking - Thanks for confirming it.
Scott
