Clear Connections or xlates using Web Interface on ASA
Oct 30th, 2008
Hi All,
I was wondering if anyone knows if ASA HTTP service/interface can support "XML" commands for clearing connections or xlates.
To be more specific, i am trying to "automate" clear connections when a radius stop accounting is sent to our radius server from a NAS.
A way to do it is using ssh or telnet script, by I do not like the idea. If there was an easy way to send an xml command, it would have been perfect.
Regards.
smahbub Wed, 11/05/2008 - 14:45
  • Silver, 250 points or more
To clear a specific connection or multiple connections, use the clear conn command in privileged EXEC mode. This command supports IPv4 and IPv6 addresses. I think that this is the way to clear the connections manually and it is not possible to clear connections automatically when accounting stop packets are sent.
pavlosd Fri, 11/07/2008 - 00:37
The thing is, not to do it using a cli, but rather using web xml for example.
