Masking Outbound Call ID on Analog Trunks
Answered Question
Oct 30th, 2008
Is there a way to mask the outbound caller ID on MGCP configured GS FXO trunks?
Correct Answer by Chris Deren about 8 years 4 months ago
POTS lines will always get overwritten by telco with the actaul number, you can not mask them.
HTH,
Chris
Overall Rating: 5 (2 ratings)
Brandon Buffin Thu, 10/30/2008 - 11:16
  • Purple, 4500 points or more
On your route pattern(s) in CCM under Calling Party Transformations, set the "Calling Line ID Presentation" to Restricted.
Hope this helps.
Brandon
wrickk_2 Thu, 10/30/2008 - 11:28
Hi Brandon, thanks for your reply. That seems to work for PRI's and T1's but not for analog trunks. It seems like the carrier over rides any attempt to transform or block the CID.
Correct Answer
Chris Deren Thu, 10/30/2008 - 11:49
  • Hall of Fame,
  • Cisco Designated VIP,
    2017 IP Telephony, Contact Center, Unified Communications
HTH,
Chris
