Help wlse wnm status authenticated but not security keys setup
Oct 30th, 2008
Hi all, i have a WLSE 2.15.2 and AP 1100 12.3(JEB), the state of the AP NM status is authenticated instead of security keys setup, they know because can be?, by this razon apparently does not send the AP the messages of RM to the WLSE, thanks.
drolemc Wed, 11/05/2008 - 09:31
  • Silver, 250 points or more
Can you try to Enable *all* radio interfaces so that they're "up" in the "show ip interfaces brief" and then redo the inventory on the WLSE. Leave them up until the wlccp link comes to "SECURITY_KEYS_SETUP". Once it comes to that state, you can shut down the radio interface.Even after a reload, the SECURITY_KEYS_SETUP will remain.To expedite the process, run a Discovery job on the AP.
galvarad Thu, 12/04/2008 - 05:20
Thank you so much for its aid, finally carry out upgrade of ACS 3.3.3 to 4,0 since find not just then this BUG. Greetings.
Trending Topics - Security & Network
