hi
i have couple of questions:
1)if i want to allocate 10mb FOR INTERneT.
int f0/0
traffic-shape groupe 150 10000000
is this work?
2)if the loopback is /32,do i need to use ip ospf network point-to-point under the lop?
3)also if the lopback is /32 and i need to use area range then must be like
area range 1.1.1.1 255.255.255.255
is this work?
thanks
Overall Rating: 5 (1 ratings)
Edison Ortiz Thu, 10/30/2008 - 11:53
Hi Ali,
1) Yes, the command traffic-shape group is often used for shaping outbound traffic on an interface. The great thing about shaping over policing is that it queues the data instead of dropping when it reaches its excess value.
For more information on this command, please see:
http://www.cisco.com/en/US/docs/ios/qos/command/reference/qos_s4.html#wp1019742
2) You don't need the ip ospf network point-to-point if the loopback is using a /32 subnet. The whole reason for this command is to announce the loopback via OSPF as /24 if the subnet was configured as /24 under the interface.
3) You only need area range under OSPF when summarizing from one area to another area. Let's say you have the following loopbacks in Area 1:
150.1.1.1
150.1.2.2
The area range command would be:
area 1 range 150.1.0.0 255.255.252.0
HTH,
__
Edison.
