Warning message
WLSE Device full names all the same.
Oct 30th, 2008
I have all of my WAP's connected and managed by my WLSE but it showing that they all have the same name under Devices > Group Management as well as when I try to deploy new templates. If I dig into device explorer it shows the "Full Name" as the wrong name but the "SysName" name is the correct name. If I log into each device the host names are correct.
Any idea's how to get the WLSE to assign the right name?
sadbulali Wed, 11/05/2008 - 10:06
  • Bronze, 100 points or more
Having the same name for all devices can happen if the name format is defined incorrectly under Device->Discover > Advanced Options. The hostname format should be %hostname%. Check if it is configured correctly and if not configure the same properly so that the issue is resolved.
Trending Topics - Security & Network
