IP Communicator with IPCC Express
Oct 30th, 2008
I'm trying to setup IP Communicator for use with IPCC Express. The issue I'm having is when the agents try to log in using the IP Communicator they can log in but when they select to make themselvs ready they are getting a message saying requesting and then it eventually times out with host not found message. Any suggestions.
Kenneth Mohammed Fri, 10/31/2008 - 09:01
  • Silver, 250 points or more
You have to associate the device name (mac address) you are using for your ip communicator with the rm user for ipcc in the global directory. Also be sure that the same device is associated with your user id in global directory. Otherwise, you will not be able to change ready states in Agent Desktop.
Hope that helped, if so please rate.
dfhensley Tue, 11/04/2008 - 12:56
That is how it is setup. I can log in, just can't change agent state. Works fine on an ip phone, just not with ip communicator. Any other suggestions.
mikram Wed, 11/05/2008 - 06:19
  • Bronze, 100 points or more
Did you check IP Agent service assigned?
Hernan Moya Wed, 11/19/2008 - 12:41
I look up your post but I can't understand what you mean. My Ip Communicator can login too but when the agent try to stay ready the message "Requesting" appears and don't work.
b.eman Thu, 03/05/2009 - 13:29
I have the same issue, did anyone ever resolve this issue?
b.eman Thu, 03/05/2009 - 15:26
Figured out my issue. I was running CIPC version 2.1.1 I upgraded to 2.1.4 and issue is resolved. This worked on 4 PCs.
