LAN to DMZ traffic ASA 5510
Oct 30th, 2008
I've heard that with a ASA 5505 the Security Plus lincese is required to pass traffic from LAN to DMA, DMZ to LAN. Is this the same with the ASA 5510?
I have the ASA5510-Bun-K9 version
ajagadee Thu, 10/30/2008 - 12:09
For the ASA5505, yes you need a Plus license to access traffic between LAN/DMZ and vice versa.
But with ASA5510-BUN-K9 license on the 5510, you should be able to use upto 5 interfaces.
Cisco ASA 5510 Firewall Edition Bundle
Includes: 5 Fast Ethernet interfaces, 250 IPsec VPN peers, 2 SSL VPN peers, 3DES/AES license
• 300 Mbps Firewall
• 170 Mbps IPsec VPN
*Pls rate if it helps*
