Kenneth Mohammed Thu, 10/30/2008 - 12:30
  • Silver, 250 points or more
I usually go to start---->settings----->control panel----->add/remove programs....scroll through this list and you should see which hotfixes have been applied to your server.
Hope that helped, if so please rate.
Jaime Valencia Thu, 10/30/2008 - 12:31
  • Cisco Employee,
  • Hall of Fame,
    2011
very simple, go to add/remove programs and you will see them
java
if this helps, please rate
