Logging log in failures
Oct 30th, 2008
  • Purple, 4500 points or more
How do I log login failures to my syslog server? I've got traps set up for notifications (6), but I'm not seeing failures when I try to log in. Is there something I need to do in the router, or can it even be done?
Thanks!
John
Overall Rating: 5 (1 ratings)
jhaegele Thu, 10/30/2008 - 14:48
in config
"login on-failure log" will log failures
"login on-sucess log" will log sucessful logins
my boss just made me figure this one out the other day ;)
John Blakley Thu, 10/30/2008 - 14:56
That's it, but I'm not getting anything in my logs. Could it be because I have RADIUS authentication first? I'm sure if I took that off it would log. I would just like to set it to log at both.
Thanks!
John
