Pix515e will not accept command
Oct 30th, 2008
I have a Pix515e running Version 6.1(4)when I go to add access-list it allows me to add them giving no error, but when I do a Sh configuration it doesn't show what I have added.
I added the same lines to a Pix515e running version 6.3 and it works fine.
Do I need to do a write memory before I do a show configuration so that it will display what I have added?
JORGE RODRIGUEZ Thu, 10/30/2008 - 14:47
  • Green, 3000 points or more
The show config command is equivalent to "show startup-config", if you din't issue a write mem after acl statement configuration it will not show in startup-config but it will show in " show running-config",you need to write mem to be able to see it in show config.
Rgds
Jorge
