VRF Import/Export - how to filter routes
rdechavez
Is there another way of filtering the routes you want to import into a vrf because the 'route-target export' and 'route-target import' imports ALL the routes tagged with the given 'asn:xx'. I wanted to have only selected routes imported from one vrf to another. Vrf 'import map' command does not work for me?
Does filtering makes sense or practical at vrf-vrf level? Where do you use 'import map' command?
thanks
resti
16 Replies 16
Harold Ritter
Resti,
The import and export maps are purposely designed to selectively import/export routes between VRFs.
Harold Ritter
Sr Technical Leader
CCIE 4168 (R&S, SP)
harold@cisco.com
México móvil: +52 1 55 8312 4915
Cisco México
Paseo de la Reforma 222
Piso 19
Cuauhtémoc, Juárez
Ciudad de México, 06600
México
Thanks Harold for your response.
Do you have an example of this especially the complete route-map used or previous topic citing this example. Cant find a sample fo this in Cisco docs.
thanks,
Resti,
Here's a very simple scenario, where you only want 192.168.1.0/24 to be exported from VRF1 to VRF2 and 192.168.2.0/24 to be exported from VRF2 to VRF1.
ip vrf VRF1
rd 1:1
route-target both 1:1
export map toVRF2
ip vrf VRF2
rd 1:2
route-target both 1:2
export map toVRF1
route-map toVRF1 permit 10
match ip address 2
set extcommunity rt 1:1
route-map toVRF2 permit 10
match ip address 1
set extcommunity rt 1:2
access-list 1 permit 192.168.1.0
access-list 2 permit 192.168.2.0
Harold Ritter
Sr Technical Leader
CCIE 4168 (R&S, SP)
harold@cisco.com
Cisco México
Piso 19
Cuauhtémoc, Juárez
México
I tried it but it did not work for me. Anything I'm missing? Here's my config, and 'show ip bgp vpn4 all', and IOS c7200-js-mz.124-16a.bin.:
thanks,
ip vrf Customer_A
rd 100:110
route-target export 100:1000
route-target import 100:1000
ip vrf Customer_B
rd 100:120
export map CE5_Export
route-target export 100:2000
route-target import 100:2000
access-list 99 permit 10.30.30.0 0.0.0.255
access-list 99 permit 10.40.40.0 0.0.0.255
route-map CE5_Export permit 10
match ip address 99
set extcommunity rt 100:1000
PE4#sh ip bgp vpnv4 all
BGP table version is 56, local router ID is 10.128.1.6
Status codes: s suppressed, d damped, h history, * valid, > best, i - internal,
r RIB-failure, S Stale
Origin codes: i - IGP, e - EGP, ? - incomplete
Network Next Hop Metric LocPrf Weight Path
Route Distinguisher: 100:110 (default for vrf Customer_A)
*>i10.128.1.7/32 10.128.1.3 0 100 0 65100 i
*> 10.128.1.10/32 10.128.4.14 0 0 65400 i
*>i10.128.4.0/30 10.128.1.3 0 100 0 65100 i
r> 10.128.4.12/30 10.128.4.14 0 0 65400 i
*>i172.100.1.0/24 10.128.1.3 0 100 0 65100 i
*> 172.100.4.0/24 10.128.4.14 0 0 65400 i
*> 192.168.1.0 10.128.4.14 0 0 65400 i
*> 192.168.2.0 10.128.4.14 0 0 65400 i
*> 192.168.3.0 10.128.4.14 0 0 65400 i
Route Distinguisher: 100:120 (default for vrf Customer_B)
*> 10.30.30.0/24 10.128.5.14 0 0 65500 i
*> 10.40.40.0/24 10.128.5.14 0 0 65500 i
*> 10.128.1.11/32 10.128.5.14 0 0 65500 i
r> 10.128.5.12/30 10.128.5.14 0 0 65500 i
PE4#
Can you please post the output of "sh ip bgp v a 10.30.30.0"
Harold Ritter
Sr Technical Leader
CCIE 4168 (R&S, SP)
harold@cisco.com
Cisco México
Piso 19
Cuauhtémoc, Juárez
México
Here's the output of that command:
PE4#sh ip bgp vpnv4 all 10.30.30.0
BGP routing table entry for 100:120:10.30.30.0/24, version 46
Paths: (1 available, best #1, table Customer_B)
Advertised to update-groups:
10.128.5.14 from 10.128.5.14 (10.128.1.11)
Origin IGP, metric 0, localpref 100, valid, external, best
Extended Community: RT:100:2000
mpls labels in/out 32/nolabel
PE4#
brgds,
I would try to remove "route-target export 100:2000" from the the following configuration:
ip vrf Customer_B
rd 100:120
Also, I would add a further statement in the route-map for the remaining prefixes, such as:
route-map CE5_Export permit 20
set extcommunity rt 100:2000
In all the examples I have seen, when they are using an "export map", they are not using it together with "route-target export" . I do not know why this is so. In your case, it seems that "route-target export" overrides the "export map". In the "export map" command documentation the expected behavior in such a situation is not defined. Interestingly, the "import map" command is required together with "route-target import" (for automatic route filtering to work I guess).
Kind Regards,
M.
Thanks M for yr reply. I did not have time to try your suggestion yet but I think I got one solution and it's consistently working for me.
I noticed that you have to clear vrf's bgp session to make sure changes take into effect otherwise SOME changes esp export/import map under 'ip vrf' section do not take into effect automatically.
Below is the command I used on the PE. With this my original configuration works.
#clear ip bgp vrf ipv4 unicast soft
e.g.
PE4# clear ip bgp vrf Customer_B ipv4 unicast 65500 soft
brgds,
Resti,
I ran into a similar issue at initial configuration. The workaround was to remove the route-map and re-apply it. A reload also fixed this issue.
Harold Ritter
Sr Technical Leader
CCIE 4168 (R&S, SP)
harold@cisco.com
Cisco México
Piso 19
Cuauhtémoc, Juárez
México
Yeah, i guess sometimes we to live with these 'undocumented features'!
Thanks&brgds,
Please consider the command "set extcommunity rt additive" in the route-map. If you omit the "additive" keyword then only the value from the route-map will be taken, whereas with the "additive" also the regular export route-targets will be used.
Harold,
What might explain the observed behaviour: modification of the export route-map will NOT trigger a re-import into BGP. So a "clear ip route" or a "clear ip bgp vpnv4 vrf..." can be required.
I usually first configure the route-map and afterwards the export map command. Usually this assures proper marking with the desired values.
Martin
Martin,
Excellent observation. It is always a good idea to configure the route-map before applying it.
Harold Ritter
Sr Technical Leader
CCIE 4168 (R&S, SP)
harold@cisco.com
Cisco México
Piso 19
Cuauhtémoc, Juárez
México
Hi Martin,
Thanks for the tips. I tested it and understand the effect of having the keyword 'additive' in it. Definitely useful feature.
Best regards,
Hi Harold,
How does VRF export work? Does it export the route regardless or does it have to be present? In your example when you export 192.168.1.0/24 from VRF1 to VRF2, what happens if the 192.168.1.0/24 route goes away from the routing table? Will the export remove that route from VRF2 automatically?
Sam
