Add a provisioned switch to a switch stack.
Answered Question
Oct 30th, 2008
Assume I have a 3 member switch stack of 3750's with the master already assigned by priority #12 and already configured and running. I want to add another member(same type and exact IOS match) that has already been provisioned (priority #1, interfaces and VLANs, etc. already configured). Reading the documentation titled "Creation and Management of Catalyst 3750 Switch Stacks Document ID: 71925" regarding the section titled the same as my Conversation Title, the 1st line completely throws me off! "When you add a provisioned switch to the switch stack, the stack applies either the provisioned configuration or the default configuration to it."
How do you get the stack to DEFINITELY accept a previously provisioned switch? By first ensuring that the existing stack has had it's current running configuration copied into it's start-up configuration? Is that it?
Correct Answer by Edison Ortiz about 8 years 6 months ago
Marc,
There are different results depending on several scenarios.
Instead of copying and pasting the information from Cisco's website, I recommend reading this document:
http://www.cisco.com/en/US/docs/switches/lan/catalyst3750/software/release/12.2_44_se/configuration/guide/swstack.html#wp1178950
HTH,
__
Edison.
Overall Rating: 4 (1 ratings)
Correct Answer
Edison Ortiz Sat, 11/01/2008 - 12:45
  • Hall of Fame,
    Founding Member
Marc,
HTH,
__
Edison.
