Cisco ACE 4710 - config backup in LMS 3.1?
Oct 30th, 2008
I installed the latest MDF that includes support for the ACE 4710, it is "seen" by CS and RME, however I am unable to get RME to fetch the config. I have checked the credentials and SNMP strings several times. I did a packet capture and it appears that the connection is being reset - not sure why. The ACE is running A1(8.0a), though I have a secondary ACE that I upgraded to the latest A3 code and I get same results. I also tried changing the transport settings in RME from telnet to ssh, still no luck.
Any guidance is greatly appreciated.
Joe Clarke Thu, 10/30/2008 - 17:04
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
ACE 4710 support for RME 4.2 is planned for early November of this year.
Joe Clarke Fri, 12/05/2008 - 10:56
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
The IDU 21.0 release for RME 4.2 is now available, and the pre-release documentation said that ACE 4710 support would be included for RME. However, the current device support documentation I have indicates that only DFM support was added. I am not sure why the RME support was dropped. You could open a service request with TAC to get more information.
chharris41 Fri, 12/05/2008 - 11:05
I will definetly do that - my main goal was to be able to back up the config's on the 2 ACE 4710's we have.
Where can I view the doc's you referred to?
