CCMServiceRW Password
Oct 30th, 2008
Is there a default password for CCMServiceRW or anyway of finding out what the password is.
I mistakenly changed the log on password within one of the services and now cannot correct it, so the service will not start.
I know I can change the passwords using the adminutility.exe but this requires a reboot of the servers, so want to avoid this at all costs.
Does anyone know if Cisco can help with this?
Jaime Valencia Thu, 10/30/2008 - 14:14
no way to find out the pwd as it's randomly generated and is different for all clusters in the world, there is no tool to retrieve that pwd. adminutility it the only way to go.
java
if this helps, please rate
