Upcoming time change
Oct 30th, 2008
Hello folks -
I have a question about the upcoming Daylight Savings time change this weekend.
If I configure my routers to synchronize time using an external NTP Server, do I still need the following command configured:
clock summer-time CST recurring 2 Sun Mar 2:00 1 Sun Nov 2:00
I know I still need the following:
clock timezone CST -6
Also, I read somewhere that Cisco routers loose time and date information when rebooted? Is that correct?
Thanks for your help!!
Joseph W. Doherty Thu, 10/30/2008 - 16:23
re: "Also, I read somewhere that Cisco routers loose time and date information when rebooted? Is that correct?"
Some do, the more powerful models and many of the newer models have on-board clocks. However, the on-board clocks can have inaccurate time, but you can have NTP update them too. (Command is something like "ntp update-calandar")
ksarin123_2 Thu, 10/30/2008 - 16:36
What do you mean by "on-board clocks have inaccurate time?"
What if you set the time manually?
Joseph W. Doherty Thu, 10/30/2008 - 16:53
Setting either clock manually is fine, but they often "drift". (I.e. gain or lose time each day. One reason for NTP.)
PS:
Also note, the on-board clock I have in mind is the calendar clock, not the since bootup running clock. Again, the former isn't available on all Cisco devices. (Commands, I recall, to see each are "show clock" vs. "show calendar".)
ksarin123_2 Thu, 10/30/2008 - 17:04
Thanks for your reply.
Do you know why do the clocks drift if set manually?
