SSH support on 3825
Answered Question
Oct 30th, 2008
Can anyone tell me if SSH is supported on the 3825 platform with this IOS release?
Release 12.4(15)XY
What I need is a release that supports SSH and a NME-TPO
Correct Answer by pkaretnikov about 8 years 8 months ago
It appears that all the images that are not marked with w/o crypto spport SSH. You should be able to do what you are looking for with even the IP base image.
The NME-TPO lists this as it's requirement
'Cisco IOS Software Release 12.4(15)XY or later'
so any of the feature sets should support it.
Hope that helps.
Overall Rating: 5 (1 ratings)
Correct Answer
pkaretnikov Thu, 10/30/2008 - 19:33
Hope that helps.
