Taking Backup of CCM 6.1
Answered Question
Oct 31st, 2008
Which protocol does the ccm use to take the backup of CCM with network directory? Is it sftp?
thanks
Correct Answer by tim.giles about 8 years 9 months ago
Yes, SFTP.
I've attached freeFTPD which most people have been using, its pretty good.
This is the following info on Cisco's website though:
To back up data to a remote device on the network, you must have an SFTP server configured. Cisco tests and recommends the following SFTP servers, but you may use any SFTP server:
Note Cisco does not support third-party software. Contact the SFTP vendor for support issues.
•Open SSH (for Unix systems)
•Cygwin (refer to http://sshwindows.sourceforge.net/)
•Titan (http://www.titanftp.com/)
Please rate useful posts...
Overall Rating: 4 (2 ratings)
Correct Answer
tim.giles Fri, 10/31/2008 - 02:10
  • Silver, 250 points or more
Yes, SFTP.
allan.thomas Fri, 10/31/2008 - 02:53
  • Blue, 1500 points or more
In addition to good information from Tim, if you have problems setting up the application, here are few simple steps:-
1. Under SFTP configure the SFTP root directory for example E:
2. Create your user and configure the home directory E:\Backup
3. Under virtual directories create a folder named Backup, set the virtual to Backup and configure the real path to E:\Backup
4. When you configure the DRS network location specify / for the path name.
Taken from one of my previous posts on a similar thread:-
http://forum.cisco.com/eforum/servlet/NetProf?page=netprof&CommCmd=MB%3Fcmd%3Dpass_through%26location%3Doutline%40%5E1%40.2cbe3d3e/3#selected_message
I have proven this setup successfully with both 5.x and 6.x
Allan.
Pls rate this post if you find it helpful.
