Cannot login to ASA5510 using ASDM
Oct 31st, 2008
Hi, I have started to get a login problem using the ASDM. When it fires up I get "ASDM is unable to read the configuration from the ASA. Please check the configuration and your conection and try again". What I find is that if I go to "File/Clear Internal Log Buffer" it tells me the Internal Sylog buffer will be cleared and then it loads the config fine. I have tried switching off logging, I have tried restricting the number of syslog messages per second but still the problem remains. Anyone any idea what the problem is?
Thanks, Ray
