High CPU on CE500
Answered Question
Oct 31st, 2008
We experience high CPU on Cisco 500 switches with average 60 % CPU and found this process running "HULC prs macro p". Does anyone know what this is ?
CE500-LANBASE-M), Version 12.2(25)FY, RELEASE SOFTWARE (fc3
Correct Answer by Edison Ortiz about 8 years 8 months ago
Hi David,
That's related to the smartport service running on the switch. Can you disable ip arp inspection and see if the CPU % decreases?
HTH,
__
Edison.
Overall Rating: 5 (1 ratings)
Correct Answer
Edison Ortiz Sat, 11/01/2008 - 13:04
  • Hall of Fame,
    Founding Member
Hi David,
HTH,
__
Edison.
davidmalan Mon, 11/03/2008 - 02:06
HI
Thanks for this information, That works fine and the CPU drop to 15%.
