Catalyst 4506
Oct 31st, 2008
am having 4506 switch along with the x4418 module. if i want to connect more than 5 cisco 3750g switch to this module,how can i do it as there is only 2 uplink ports.please let me know
Edison Ortiz Sat, 11/01/2008 - 13:09
  • Hall of Fame,
    Founding Member
Rajesh,
You can connect these switches to all 18 available ports. The so-called 'uplink' ports are mentioned as a way to differentiate the available throughput. Those ports are able to supply wire speed services while the remaining 16 ports are supplying oversubscribed services 4:1.
HTH,
__
Edison.
Please rate helpful posts
