No media ressource on H323 VG
Answered Question
Oct 31st, 2008
Hi guys,
I have a CM6 with H3232 VG with E1 PRI.
I manually specified the MRGL on the gateway (not from the device pool). Everytime I try to make a conference with an offnet call, the offnet party gets disconnected. If i place that call on hold, i don't listen to the MoH, instead i get a quick beep. I tried to configure MTP on the VG but for some reason it doesn't work with CM6.
Any help would be much appreciated.
Correct Answer by Jaime Valencia about 8 years 2 months ago
what codec do you have configured for the dial-peers??? SW CFB can only handle G711 and only codec MOH has enabled by default is G711
H323 default codec is G729
by your description it does sound like codec issues
java
if this helps, please rate
Overall Rating: 5 (1 ratings)
Correct Answer
Jaime Valencia Fri, 10/31/2008 - 05:18
java
