Warning message
Can I drop an inbound to outside interface connection to my ASA 5520
Oct 31st, 2008
From Netflow Analyazer I can see a connection from an external IP to my ASA's outside interface that's been going for 2 hours and downloaded 3GB of data so far, how can I kill this conenction? It's a http connection.
cisco24x7 Fri, 10/31/2008 - 06:33
  • Silver, 250 points or more
you can shun the connection or perform a "clear
xlate" on that connection
whiteford Fri, 10/31/2008 - 06:36
Thanks, would do I type after "clear xlate"? if the IP I need to drop is 1.2.3.4?
srue Fri, 10/31/2008 - 07:13
  • Blue, 1500 points or more
clear local-host is good for this also.
whiteford Fri, 10/31/2008 - 07:23
Thanks, will this drop that single external IP that's comming inbound? I don't want to drop all connections.
Brent Rockburn Fri, 10/31/2008 - 09:36
Why don't you just put up an ACL blocking that IP on the outside interface?
